2001 S60 Lack of Power
Old Aug 7, 2023 | 07:50 PM
Ezsalad's Avatar
Default 2001 S60 Lack of Power
Hello, I am new to this forum. I have a 2001 s60 173,000 miles, that I inherited from my niece. I have resolved several problems after reading many of your previous posts. But now I am not sure where to go with the current problem. The engine has a replacement Xenodex ETM. It starts fine idles perfectly but when placed in gear it will not rev above 1000 rpm until it has warmed up. After that it will accelerate in sporadic spurts once you get rpm above ~ 2000 rpm. I have a code reader that is specific to Volvo and can monitor engine parameters. Once car is up to highway speed cruise control will maintain speed on most fairly level roads, hills cause serious downshifts and engine revving to maintain speed. I have monitored O2 sensor, MAF, Manifold vacuum, timing advance, knock timing retard, and injector time. O2 reads .73v @ idle, .02-.05v all other rpm’s (way lean). Checked fuel pressure ~ 50psi steady (gauge reading no sensor model), timing is all over the place -5 deg to 36 deg coasting down hill. Retard 0 to 20 deg. The most confusing though is injection time, most of the time when cruising it registers 0 us(micro seconds) but under hard acceleration it jumps from 0 to 10,000 us (10 milliseconds) for a second or two then back to 0 then back and all over between 7,500, 9300. But never stays always constant. I removed the ECM and checked for broken solder joints none noted. I’ve checked throttle position desired vs actual and they appear to correspond. MAF and manifold pressure register as expected. Any guidance you can provide would be greatly appreciated. To dated I’ve replaced plugs, one bad coil pack, resolved one major vacuum leak(disconnected hose causing stalling and starting issues). Such a nice car but the acceleration issue is major hazard when crossing roads or entering highway from a crossroad.
manofsteel05
Aug 25, 2022 05:39 PM
mabbott
2001-2013 model year V70
Feb 23, 2018 07:32 PM
onlyforproblems
Feb 26, 2017 06:23 PM
Fedya
Mar 5, 2013 05:38 PM
Nathan DuBow
Jul 26, 2012 12:46 AM
