2001 s60t rpm varies
Old Oct 5, 2009 | 07:07 AM
finaddict4's Avatar
Default 2001 s60t rpm varies
While stopped in gear, engine lunges when rpm's vary. Runs fine while underway. Any ideas? Thanks
Old Oct 6, 2009 | 10:21 AM
ranger_00953's Avatar
I have a S60 T5 2002 and my problem is that when I'm running on a steady pace not fast my rpm's start to make an intermitent pull's. I have already put new spark plugs on it, check the spark plugs connector and the problem still there, anyone can help me with any ideas?
Old Oct 6, 2009 | 08:43 PM
twisouism's Avatar
Thanks so much for sharing the post.
Old Oct 6, 2009 | 08:49 PM
VOLVO15's Avatar
My S60 did that while I was stopped and turned out the Throttle Unit was bad. It was a $1000 repair, but luckily it was under an "Extended Warranty" (AKA "Recall"). Anyway not sure if it is the same thing with you but you may want to check that out with a VOLVO mechanic.
Ksagal
Feb 15, 2015 08:20 PM
mphubbar
Feb 10, 2006 03:30 PM
spinningcain
Jan 19, 2006 07:56 PM
johnoswald
Jan 9, 2006 08:50 PM
NEED4SWEDE01
Jun 28, 2005 10:34 PM
