2002 headlight VS 2005+ headlight
Flares are Heico, about $400 for the pair, no side skirts.
As far as the wiring goes, there is a yellow wire from the headlight assembly that needs to be connected to the chassis. The wire takes all the grounds and brings them to a single yellow wire which you need to extend and bolt to the grounds on each fender, look and you'll see two or three bolts on each side under the hood that have a bunch of wires running to them, these are chassis ground, that's where you connect the yellow wire from the headlights.
darkostoj
08-01-2018 09:27 AM
