2002 S60 Base with Auto climate control, issues.
Did the base model of the S60 had the option for the auto climate control? The owner's manual says it's for the 2.4T and T5 and my base model has it.
My AC is not working properly so I'm initially blaming it on this. It seems the previous owner had work done on the climate control because there are marks on the bottom of the radio bezel as if it was pryed out before.
If I install the original manual climate control will it fix everything? It never seems to keep it at the temperature I set it to and when I move the blower control the auto light stays on. Also the recirculation button when pressed only lights up once for manual.
Thanks in advance.
Thanks in advance.
my'94 940
03-15-2014 04:00 PM
bond007
01-27-2011 03:49 PM
