2002 Volvo s60 2.4 Turbo Rims *Help*
I own a 2002 volvo s60 2.4turbo, and i have recently bought 20 inch rims to go on it. I have the right lug pattern i just dont know if they will fit without rubbing. Do i need to lift the suspension? or can i just put them on there? has anyone ever put 20s on their s60?
I'd assume you'll run into rubbing issues, and even more so depending on the width of the wheel. Also, even though you have the right bolt pattern, you need to make sure the wheels have the correct hubcentric size rings. To my knowledge there are no "lift kits" for the P2 S60's, so if they don't fit, I really don't know what to tell ya. I'd say, once you get your tires on, throw them on the car and see what happens... I do know 19's will fit on a lowered S60R with the fenders rolled. So you may be able to get away with it.
You're tires are gonna be wicked low profile so I'd be very concerned about destroying the tires and wheels if you hit any pot holes or other road blemishes.
Yep, 18's. I had to slightly roll the front fenders but once I did that, I didn't have a single rubbing issue. And I only had to roll the fenders cause that car has about a 1.75" drop on it. But it's a completely different car then you S60.
I still say, you should jack up the front and put the wheels on there and see how they fit. Only take you 10-15 min.
TXS60T5
06-13-2013 11:56 PM
