2003 S60, auto trans. drainplug?
Yes. The trans drain plug is pretty unmistakable. I used an adjustable wrench so I don't remember the correct size, but yeah, 24mm sounds accurate.
I recall Pentosin brand being recommended for power steering; I think Pentosin CHF 11S. You can search online for a good price. It is pricey stuff though.
my owners manual says to use "Volvo Power Steering fluid" quite expensive, and greenish in color and almost seems a little thicker than ATF. Though when I drained out my power steering reservoir there was clearly some red color to the fluid in it, and from the receipts I got with the car this car has only been to Volvo for all its servicing(and with only 58k on the clock and no signs of leakage I would be surprised if much topping off had ever been needed...)
nortons
02-22-2015 11:14 PM
