2004 2.4T engine swap help!
![Exclamation](https://volvoforums.com/forum/images/icons/icon4.gif)
I recently swapped in another engine due to my last engine going bad. I plugged everything up except one plug that looks like an injector clip the wire colors are green/gray and green. The car starts up and sounds like its running off of 4 or 3 cylinders. I went to the store to check it up with a OBD2 computer check up. i got three codes that i really need to solve.
P1618
P0243
P0748
I would like to know the problems and solutions for these three.
The OBD2 did not say i had any problems with injectors, sparks, or coil packs.
Your help will be greatly appreciated.
P1618
P0243
P0748
P16XX Computer and Auxiliary Outputs
P0243 Turbo/Super Charger Wastegate Solenoid “A”
P0748 Pressure Control Solenoid “A” Electrical
looks like you have some electrical issue with the transmission, check all the cables and plugs and reset your computer then scan it again and see if the same codes pop up.
