Engine swap vs. rebuild 2004 s60 B5244s6
Old Sep 20, 2014 | 03:07 PM
rb04S60's Avatar
Default Engine swap vs. rebuild 2004 s60 B5244s6
So, I bought this Volvo with a bad engine/spun rod bearing. Come to find out that it is the dual advance cam vs. single cam (B5244s) most commonly found used engine. Bought one, is wrong so I'm having to rebuild or use just the block from the single advance engine. Which from what I have researched will work. Nonetheless, the job to take apart all related components and do this right is challenging. I'm buying a camshaft/cam cover tool kit to start and taking apart from there on. I do have mechanical experience and feel up to this task. Nonetheless, is/has anyone doing/done this rebuild/take apart and put together successfully? There is a lot of money and time riding on this rebuild and would appreciate someones knowledge and experience. Thank you
sjackson
Oct 25, 2018 05:49 PM
Disco2
Feb 21, 2016 07:22 AM
on1wheel01
Jan 15, 2014 09:47 PM
ArtumShalya
Jun 11, 2012 12:21 PM
axis72
Feb 11, 2006 05:29 PM
