2006 volvo s60 2.5t NO power to Fuse #6 & #8
I have not power to anything and car won't start. There is no power to fuse #6 & #8 in the fuse block by the drivers door.
if I power fuse 6 or 8 with a power probe everything turns on and car starts. any suggestions ? |
Are you getting any warning messages regarding the immmobilizer ? (if so google "volvo s60 antenna ring") Another thought is that the PNP sensor in the shifter could be thinking the car is not in park thus won't allow the starter to engage. Try rowing the shifter from park to lo quickly 10-20x, then make sure the shifter button is fully popped out. See if that changes the power. Did you also check the master fuse box and relays?
S60
No messages or codes. Immobilizer has been changed. Park lock checked and good.
S60
Changed out the ingition switch today. Didn't help.
need to know where the power comes from the those fuses. Anybody got a wiring diagram that can look. |
