2006 volvo s60 2.5t NO power to Fuse #6 & #8
Old Jan 8, 2019 | 06:28 PM
Jffrontline's Avatar
Default 2006 volvo s60 2.5t NO power to Fuse #6 & #8
I have not power to anything and car won't start. There is no power to fuse #6 & #8 in the fuse block by the drivers door.
if I power fuse 6 or 8 with a power probe everything turns on and car starts.
any suggestions ?
Old Jan 9, 2019 | 01:58 PM
Are you getting any warning messages regarding the immmobilizer ? (if so google "volvo s60 antenna ring") Another thought is that the PNP sensor in the shifter could be thinking the car is not in park thus won't allow the starter to engage. Try rowing the shifter from park to lo quickly 10-20x, then make sure the shifter button is fully popped out. See if that changes the power. Did you also check the master fuse box and relays?
Old Jan 10, 2019 | 12:18 PM
Default S60
No messages or codes. Immobilizer has been changed. Park lock checked and good.
Old Jan 13, 2019 | 07:13 AM
Default S60
Changed out the ingition switch today. Didn't help.
need to know where the power comes from the those fuses. Anybody got a wiring diagram that can look.
Wesley brown
Sep 9, 2015 10:37 AM
09XC90
Aug 2, 2015 08:40 PM
T K
Mar 22, 2011 03:32 PM
dornon13
Mar 13, 2009 02:04 PM
jmwsmith
Nov 15, 2008 01:31 PM
