Just need assistance with finding the location? Fuel pump relay for 2007 S60. Family members vehicle they been without a ride for 3 months.. thank you in advance
You need to look somewhere else. A 2007 s60 turbo or not does not have a fuel pump relay. If there's a fuel pressure sensor on the end of the fuel rail - there is however a fuel pump controller, or a PEM. That makes the fuel pump run on demand, not at full speed. Without a fuel pressure sensor there is no controller and power comes directly from the CEM (as shown below). On some cars the controller does have problems - some were mounted on the side on the gas tank slightly in front of the right rear tire - and were subject to corrosion problems, worse in salt country. If mounted outside there was an update to move the controller inside the car to fix that.
