2011 S60 T6: Front Passenger Door Won't Open From the Inside
Old Feb 7, 2012 | 12:17 PM
discodave's Avatar
Default 2011 S60 T6: Front Passenger Door Won't Open From the Inside
I just bought my 2011 S60 about 6 weeks ago and my front passenger door won't open from the inside. It lock and unlocks just fine, but when you pull the handle on the inside nothing happens.
First, has anybody else had a similar issue with a brand new car?
Second, this should be covered under warranty correct?
Thanks!
Old Feb 8, 2012 | 07:25 AM
bobamoo's Avatar
I would certainly hope they would cover under warranty! Have you taken it to your dealer?
Old Jan 16, 2013 | 11:12 PM
msbrown88's Avatar
Default I have the same issue
I have the same issue on my 2002 S60. Did you ever find out what the problem was?
Old Jan 18, 2013 | 03:46 PM
01_fast_ride's Avatar
If you are able to open the door from the outside but not from inside, the cable that pulls on the latch mechanism may have come loose. Open the door, then remove the inner door panel. That should give you a good look at the problem. The cable, if it came loose, just snaps back into place. Check the operation of the inside handle before buttoning it up.
karutunian
Mar 27, 2021 05:44 PM
xevo
Dec 21, 2015 05:48 PM
muncitoru
Jun 14, 2013 10:09 AM
lgarrett0109
Sep 28, 2012 10:16 PM
James66666698
Sep 6, 2010 04:29 PM
