my 2013 s60 is leaking oil in the middle front between the tires it is leaking on the ground and leaving a small puddle i checked the oil level and its fine where do you think the oil leak is coming from
There is a plastic shroud underneath that unless removed is hard to spot the source of leaks. In the case of my S60, it was the turbo leaking at an internal seal.
