2014 S60 radio hard to turn off
Old May 29, 2015 | 05:50 AM
carken's Avatar
Default 2014 S60 radio hard to turn off
It takes as long as 15 seconds holding the OFF button to shut down the radio. Is this normal?
TIA
Ken
Old May 29, 2015 | 09:27 AM
zerorisers's Avatar
This should not be normal as anybod who designs electronics makes things simple for the user. if they protected from accidental touch they would make you hold it down for 1-2 seconds, not 15.
Has the car had any previous owners?
Has there been any kind of liquid spill in the radio, or any other electrical problem in the car?
Has there been any "mishandling" or poor treatment of the power switch?
(I would assume carbon buildup but it is just too new)
(seems pretty new to me as I use a 2002 s60 and the radio is just recently in the last year messing up.)
Old May 31, 2015 | 05:34 AM
carken's Avatar
no, I've only had the car about 6 months. It just seems odd to take so long to shut down.
TIA
Old Jun 1, 2015 | 08:44 AM
zerorisers's Avatar
TIA
Might you be able to provide a model number for the radio?
Old Jun 1, 2015 | 12:43 PM
Try a quick test - with the key off (and out) see if you are still getting voltage to the radio on the power lead (ie test at the fuse). It is possible you have an ignition switch issue or even a voltage regulator that is feeding voltage backwards from the battery (ie bypassing the key). If there's power with the key off, then try disconnecting the voltage regulator (ie at the alternator). If there's still power, I'd blame the ignition switch.
Old Jun 1, 2015 | 12:50 PM
ES6T's Avatar
They do take a while. But 15 seconds sounds long.
suckonthiscaravan
Dec 5, 2018 03:19 PM
roblinds
Jul 7, 2014 06:22 PM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
