2014 TPMS problem?
I watched a few YouTube videos on how to recalibrate the TMPS on a 2014 S60 T5 but I am getting nowhere with this.
I press the my car button and use the ok button to select My S60, when I do that it only shows the traction control system and the forward collision prevention system, I do not see a sub menu selection for TMPS. Is there something I missed?
Related to the TMPS does the system give a live read out of each tire's pressure or is it a general warning light if there is a low tire?
If you have tire pressure sensors in the wheels (your owners manual page 316 says you do) https://volvornt.harte-hanks.com/man...ers-Manual.pdf
The tpms "recalibrates" (turns the warning light off) by simply driving the car after setting the correct pressure in all 4 tires. (the spare does not have a sensor)
There are indirect systems (such as used in my 2020 xc60) that use the abs sensors to detect a low tire - and those do require a button push to "recalibrate" and turn the light off.
