2022 S60 B5 Winter Wheel Options?
Old Jul 10, 2022 | 05:31 PM
Rollieman's Avatar
Default 2022 S60 B5 Winter Wheel Options?
Hi,
Looking for a new set of 18 X 8 steel wheels for a 2022 S60 sedan for the winter to replace the 19 X 8.5 Diamond Cut wheels.
I've searched the web with no luck, although there are several inexpensive 18 X 8 alloy wheels available that fit.
Thank you,
Old Jul 11, 2022 | 10:26 AM
The 2022 uses the same size as prior years ie 5x108, 63.4mm center bore, 8Jx18 ET42 or 7Jx17 ET40.5's will work stock tire sizes for those rims would be the 235/45-18 or 225/50-17s. You can shop sites like tirerack.com or discount tire direct for packages with aftermarket rims. I found a set of Volvo factory style rims for my S40 at hubcaphaven.com. How about something like this?
https://www.hubcaphaven.com/p/25938/...322071564.html
Old Jul 11, 2022 | 11:32 AM
Rollieman's Avatar
Thank you very much mt6127, those specs are EXACTLY what I was looking for.
Now I can hopefully find some steel rims that meet those specifications?
Old Jul 11, 2022 | 02:20 PM
FYI, many FWD Fords and Volvos made after 2010 share the 5x108, 63.4 CB spec.
Here's something to look at:
https://www.carid.com/rt-wheels/17-s..._id=1373190199
hezekiah777
Nov 11, 2021 03:04 PM
volvomania69
Oct 27, 2011 12:42 PM
lvoll1972
Sep 23, 2009 01:52 PM
robert213
Jul 24, 2005 03:56 AM
pete13
Apr 19, 2005 10:56 PM
