4" Downpipe on 2.5T FWD
I want to have a muffler shop install a 4" downpipe on my 2005 2.5T FWD Auto tranny. I will be putting in the OBX catback at the same time. Anyone put in a 4" downpipe and been able to fit it? I only have found one downpipe for the FWD 2.5T and it was 3" mandrel for $1500. I can get a 4" press bent for 1/3 that price. Any info about anyone with a 4" DP on the 2.5T FWD would be appreciated!!
I also want to retain a cat - probably a 4" race cat - so that I won't get a CEL and will pass emissions.
Thanks,
Casey
Thanks,
Casey
Why not go with The OBX downPipe. I have it and run it Catless(o2 45% spacer = No CEL) Many guys have done this $150 for the Pipe and have a HiFlow cat welded in if you want. Remember that for the Car to get any real gains from the DownPipe or any real Performance part(Exhaust,FMIC,HI-Flow intake) The car needs to be Tuned to utilize it.But the biggest DP i have seen is from Elevate(http://www.elevatecars.com/) 3.5". Most if not all DP are going to run you $895 or better. OBX for me is the way to go.
I didn't know OBX made a DP for the 2.5T till today. The pipes all say for 2.4T or R. But I am now told that 2.4T FWD pipes fit the 2.5T FWD so I'm going to order one of those.
So, for the 2.5T FWD I need a 45 O2 sensor spacer or a 90 for the OBX Pipe to fit? Anything else I need to get? I'm going to order the cat back and DP and have them installed at the same time.
Thanks,
Casey
Thanks,
Casey
I used this http://www.namotorsports.net/detail....d/DD-EX-99-200 Worked perfect. One thing you have a FWD car so when putting in the DP you need to rework the rear O2 sensor. The stock location and new OBX is different. It will fit just something to keep an eye on. http://forums.swedespeed.com/showthr...&highlight=OBX GL
Got the OBX DP and Cat-back installed today. Muffler shop charged me $130 to install. They had to take out some of the pipes as it was too long (others mentioned this issue as well). I'm very happy with the power and the sound isn't bad. I drove it about 150 miles today, and I get no check engine light (knock on wood). I went with the "no cat" option and the 02 Spacer, so it's straight through exhaust. The exhaust is fairly quiet at low accelleration, but at medium and heavy acceleration it gets ALOT louder. Has a deep sound. Sounds a little ricey, but not horribly so. I did have one of the electrical wires (02 possibly) that they had left touching a heat shield after the install. I smelt it start to melt after about 15 mins of driving and pulled over. It didn't do any major damage and I was easily able to wrap it around a hose and get it away from heat shield.
One issue though: rattles. Under moderate acceleration.. right at 3000 RPM (when it really starts resonating) I get a rattle. I thought it was heat shield from top of engine (right over the DP at back of engine). I tightened that down but it didn't fix the issue. It sounds like it's coming from under the hood instead of further back, but it's hard to pinpoint. I will keep an eye out, but if anyone wants to hazard a guess at where it could be coming from or whats causing it, feel free.
Thank you, I will look into that.
While in Park today I revved the car hard to listen for rattles. I get a slight pop in the upper rpms, almost like a backfire. I haven't had my car tuned yet, but have you experienced this as well? I am assuming either car is running rich or there is a hole in the exhaust somewhere.
Thanks,
Casey
Thanks,
Casey
Thanks,
Casey
Thanks,
Casey
The Tune will make all the difference in the world. I have and 03 S60 AWD geartronic 2.5t and stock its 208hp. My tuner (Elevate-AutoTech)thinks that i will see 250hp .Thats pretty good but the biggest difference for me is the Torque 236 stock 310 tuned that's the biggest difference with an AWD the car pulls harder in the lower Rpms.But all in all the Tune turned my car in to some thing very different than i bought. Crazy that there is so much there just locked away.
Cyclenby
Feb 14, 2011 11:02 AM
Platinum52
Apr 17, 2008 06:10 AM
