60K Service
Old Nov 25, 2011 | 06:19 PM
allen downing's Avatar
Default 60K Service
where are the spark plugs located on the 2.5t and the cabin air filter
Old Nov 27, 2011 | 08:57 AM
MYS6T's Avatar
spark plugs are located under the Plastic piece on the top of the engine. Remove the over the engine pipe(Charge Pipe). Under there you will see the 5 coil packs with 2 10mm bolts i believe is the size.Unplug and Remove the 2 bolts pull out coil pack and with a spark socket and extension remove the plugs. Very easy to do just make sure that you do not over torque when reinstalling the plugs. Cabin filter is below the glove Box just remove lower dash piece and you will see where it goes... GL
Old Nov 30, 2011 | 02:58 PM
Thank for the info, you were quite helpful. Regards
Arcson
Jun 6, 2011 08:34 PM
Tacodog
May 9, 2008 10:38 PM
MattS77
Jan 22, 2008 06:27 AM
tcrossley
Jan 21, 2007 06:37 PM
gordon368
Nov 17, 2005 11:54 PM
