AC recharge after condenser replaced
Old Apr 18, 2020 | 04:00 PM
greenfoot's Avatar
Default AC recharge after condenser replaced
I replaced the AC condenser on my 2008 S60 2.5T after some minor front end damage. No real problems there.
However, when adding refrigerant, I can't get the full amount in because the compressor wont come on. Compressor wont come on because the pressure is too low.... but I can't get the pressure up in less the compressor comes on. Sort of a Catch-22.
Any tips on getting the compressor to come on so I can get that last pound of r134A in?
Thanks,
John
2008 S60 2.5T
Old Apr 18, 2020 | 05:53 PM
you really should have the system professionally charged so they can evacuate the system of all impurities/moisture etc and put in the correct amount of oil. With that said, you should be able to jumper the low pressure sensor to allow the compressor to kick on. Look on the line coming from the firewall into the compressor
Old Apr 18, 2020 | 08:36 PM
ES6T's Avatar
Yeah the system really should be put under a vacuum first. Then it basically fills itself.
rajib
May 3, 2016 06:24 AM
schloet
May 27, 2015 06:43 PM
sghokie
Jul 25, 2011 05:00 AM
volvo family
Oct 8, 2010 02:35 PM
alexdelove
Aug 13, 2007 12:12 PM
