Aftermarket parts
Old Jun 27, 2016 | 06:41 PM
Rosegirl's Avatar
Default Aftermarket parts
I have a 2005 S60 that I'm getting estimates on to replace timing belt kit w/ water pump, cam shaft seals, and breather hose. Why is it that all of the mechanics that have given me an estimate tell me that putting in genuine Volvo parts is the way to go? I saw a sticky on this forum with several names of aftermarket providers. What is the consequence of using aftermarket vs Volvo parts?
thanks
Old Jun 27, 2016 | 06:53 PM
ES6T's Avatar
Because putting on a cheap water pump isn't worth saving $75 if it seizes and shreds the belt and bends all your valves.
Old Jun 28, 2016 | 08:35 PM
Steve H.'s Avatar
Get the Asian brand kit with water pump from Rockauto.com. Asian is the OEM water pump manufacturer for Volvo. Otherwise stay OEM
Old Jun 29, 2016 | 08:37 AM
FCPEuro and IPD sell timing belt kits which give you a choice of Volvo OEM, Aisin (lol not Asian) or other aftermarket brands. Volvo OEM are known to be very stout to the point some recommend doing the pump every other belt change on the models with the 70K change intervals so I'd go that route and not worry about it for the next 100K miles . The "full" kit should also include the tensioner/dampener and idler, the timing belt and seals for the cam shafts and crank. Note doing the cam seals on the 2000+ models is a pain since you the VVT gear to deal with (requiring cam locks and a reset procedure) so I'd look for a mechanic with Volvo experience. Also its a good time to refresh the serpentine belt and the idlers there as well. I would also pull the timing cover to see if you do have a cam seal leak as well before you have the work done. If you do, its likely that you have a clogged PCV and will need to consider a refresh there as well.
andrew123
Canada, Over Seas & Elsewhere
Jan 9, 2011 05:09 PM
anjellenee
Dec 29, 2008 06:48 PM
SloptownRat
Intake, Headers and Exhaust
May 7, 2007 11:46 AM
floatingfast
May 12, 2006 09:05 PM
Robbyboatz
Nov 11, 2004 01:40 PM
