Automatic shift knob replacement
Thanks, Tech for the info...So there is no set screw to hold it in place? Just twist the boot were it connects to the shifter and pull up. Is there a catch were the boot untwist and twist back for the install. Thanks again!
Once you get the **** off you will see. There is tabs that the Square ring locks onto. When you install the new one the Square ring in the boot you can just pull it up and it should lock on. It might be a little tough but it will go.
martymcfly1985
Jul 29, 2014 02:36 AM
daviddward1
Oct 30, 2011 11:22 PM
