AUX and SAT in s60
AUX and SAT in s60
is their any aftermarket kit that is compatible with the FACTORY radio system to give my stock radio AUX capabilities? i am tired of using a FM transmitter to listen to music because of all the static!
also, is it possible to have satellite radio in the s60? I've seen the label for it on the screen of the stock radio system and i don't want to buy an XM radio car kit because of the fact that it must use up a cigarette lighter port and that it wouldn't look professional.
and i don't want to have a aftermarket radio system, i don't want to alter my car that much.
what are my options
what are my options
The USA Spec (PA-11 VOL) is a popular choice. I had one before upgrading to an aftermarket system. If you have the HU-650, the unit plugs into the cd-changer slot on the back of the stock unit (which means you lose your changer if you have one and are using it). The USA Spec unit has an iPod connector and standard RCA to connect an aux patch wire to.
I had intermittent quality issues with mine though. Some days it worked, some days nada.
john
07-10-2006 07:19 PM
