Battery advice
I do not know what towing electrics is , is it the plug for a tow bar , if so just disconnect the battery do the wiring and reconnect all the codes will be fine for al least a few days on a new car like yours , you may have to reset the steering by turning lock to lock if yours has electric steering
Just realized from your post how many Batteries do you have? is yours a Hybrid?
Ok did not realize that stop start needed 2 batteries , on my Alfa it has only one but must say its a bit problematic as a result so 2 is probably a good idea,
Anyway I am not sure if you need to disconnect both as the smaller one may be used for other functions besides stop start as stop start requires a lot of power so probably uses both
ceph0411
12-10-2023 08:05 AM
engineered
2001-2013 model year V70
07-19-2012 11:30 PM
