How to reset the Battery Monitor Sensor for 2016 V60/2017 S60?
Old Apr 20, 2020 | 05:12 PM
ceph0411's Avatar
Default How to reset the Battery Monitor Sensor for 2016 V60/2017 S60?
Hi all, I am wondering how to reset the battery monitor sensor after you replace the battery. The dealership kept telling me only they or people who have VIDA can do it or it'll cause all sorts of problems, like currently my start/stop not working at all for my 2016 V60 (the button light does come on though) is due to the battery issue - the dealer said if you put 3rd party battery (which will be 200 dollar cheaper than if they put it in for me) without the dealer's resetting it then you can still drive but you will have limited functions and you'll have to replace the battery every year, etc...I am guessing what works for the older Volvos, like disconnecting the negative terminal for 10 minutes, won't work for mine?
BTW, the dealer said both the main and 2nd battery need to be replaced, I can't seem to find the specs on the manual for the 2nd/auxiliary battery. Where is the secondary battery and is there 3rd party battery I can buy too and do it myself? Also, if I just replace the secondary battery, do I need to reset BMS too?
Thanks.
2019 XC60
2017 S60
2016 V60
Old Apr 20, 2020 | 07:23 PM
There's a few vids on youtube for hacks on resetting the bms without VIDA. here's one.
Old Apr 21, 2020 | 10:41 AM
ceph0411's Avatar
Just found this one myself too! Looks pretty simple, will try it out today thanks!
Old Apr 21, 2020 | 05:22 PM
ceph0411's Avatar
https://www.youtube.com/watch?v=iu9z5m78Szw
Just wanna give a quick report about this trick, it seems to work well! The long lost start/stop function came right back! Both the dates and BLIS function icon started appearing on the screen, which I haven't seen before. Obviously the previous owner didn't reset BMS when the battery was replaced before.
Old Jul 7, 2020 | 05:53 AM
V60roc's Avatar
This worked on my 2018 V60. Thank you for posting!
Old Dec 10, 2023 | 08:05 AM
e97maja's Avatar
Default 2016 V40 Phase II
Hi, just changed the battery on my wifes V40 II. There was a need of four pushes to the hazard light button instead of three on my specific modell. Otherwise the same procedure.
Many thanks for the help!
lj74
Jan 22, 2024 04:27 PM
Joana Elisa Cappi
Apr 16, 2020 01:36 AM
urdrwho
Dec 19, 2019 01:18 PM
timer00
Dec 23, 2010 09:03 PM
