Bi-xenon lights problem, S60, 2015
Hello,
I'm driving S60, 2015. It have Bi-xenon lights. Since yesterday, I have problem with left light. When I set it to auto mode, after few minutes light stop working, and when i switch it manually to off, then again to auto it start then again after few minutes stop. So, what is common issue for this problem? Thanks This is message that is written when it stops https://i.ibb.co/fQWp30w/20220405-183609.jpg |
if you have the time, try swapping the bulbs left/right then swap the ballasts. If the problem moves to the other side, then you have the culprit.
Originally Posted by mt6127
(Post 510204)
https://i.ibb.co/0B4j4Y3/20220408-140920.jpg |
D3S (35W) is the bulb type, I recommend ordering them from FCPEuro because they are expensive bulbs. They have a lifetime warranty policy, even for bulbs. So if you plan on keeping the car for some time, your next ones will be reimbursed.
You can replace individually. I believe they are sold individually as well. |
I bought these two, there is some positive reviews
GT Ultra Xenon D3S | Single Headlight Bulb | PowerBulbs EU |
Ahhh, EU. Designed in Germany, Cant go wrong
Originally Posted by Dingus1
(Post 510365)
