Bi-xenon lights problem, S60, 2015
Old Apr 6, 2022 | 06:36 AM
luka78's Avatar
Default Bi-xenon lights problem, S60, 2015
Hello,
I'm driving S60, 2015. It have Bi-xenon lights. Since yesterday, I have problem with left light. When I set it to auto mode, after few minutes light stop working, and when i switch it manually to off, then again to auto it start then again after few minutes stop. So, what is common issue for this problem?
Thanks
This is message that is written when it stops
Old Apr 6, 2022 | 04:11 PM
if you have the time, try swapping the bulbs left/right then swap the ballasts. If the problem moves to the other side, then you have the culprit.
Old Apr 8, 2022 | 07:53 AM
luka78's Avatar
Thanks for advice. I swap it and confirm that bulb are causing the problem. Do I have to change them both at the same time? This is the type of bulb, or you recommend some other type:
Old Apr 8, 2022 | 10:34 AM
Dingus1's Avatar
D3S (35W) is the bulb type, I recommend ordering them from FCPEuro because they are expensive bulbs. They have a lifetime warranty policy, even for bulbs. So if you plan on keeping the car for some time, your next ones will be reimbursed.
You can replace individually. I believe they are sold individually as well.
Old Apr 11, 2022 | 06:32 AM
luka78's Avatar
I bought these two, there is some positive reviews
GT Ultra Xenon D3S | Single Headlight Bulb | PowerBulbs EU
Old Apr 11, 2022 | 06:39 AM
Dingus1's Avatar
Ahhh, EU. Designed in Germany, Cant go wrong
Old Oct 17, 2022 | 06:57 AM
luka78's Avatar
You were right. After several months of use, they become purple. I got refund without problems.
luka78
Apr 6, 2022 06:25 AM
zoesyd
Jun 24, 2019 09:48 AM
Harpersaj
May 3, 2018 01:54 AM
Harpersaj
May 1, 2018 12:57 PM
rmarshall
Jan 3, 2018 01:52 PM
