bov on a 2007 s60 2.5t
Old Sep 18, 2020 | 08:17 AM
MeatMountain's Avatar
Question bov on a 2007 s60 2.5t
I'm starting to upgrade my 2007 s60 2.5t and I'm wondering if its possible to get a bov put on (for the sound mostly) then get a tune so it doesn't run rich when the air from the cbv is supposed to recirculate. Would this get rid of some of the cons of just putting on a bov?
Old Sep 23, 2020 | 06:43 AM
Arron Somerville's Avatar
im looking into it aswell i have bought a hybrid blow off valve!
you want one of these it bolts in place of the recirc valve on the turbo its a adapter then you put a hyrbid blow off valve on the adapter you need this as the origional system is a recirculated one so you want some of the boost recirculated to keep everything happy
https://www.forgemotorsport.co.uk/Bl...hoCjMYQAvD_BwE
you can clamp this hose onto it then the hybrid 35mm valve clamps onto the other side then you must route another pipe back into your intake
https://www.ebay.co.uk/itm/Silicone-...IAAOSwjyhe13e4
using something like this
here is the one you can use the silicone hose
https://www.ebay.co.uk/itm/Silver-Bl...gAAOSwcH5e4S9B
then you can have something like this inline on one of your intake pipes(someone may be able to advise a better way to route the bov outlet back into the intake)
metal
https://www.ebay.co.uk/itm/Dump-Valv...EAAOSwc~tbPkDo
silicone
https://www.ebay.co.uk/itm/Silicone-...wAAOSwrWBeJuKq
these are just for refrence you will need to make sure your hose sizes all match up thats not my strong suit!
but hopefully this gives you a rough idea of what you need to do
i would go for a more expensive valve but maybe buy the cheap one first to see how you like it
or you could use this blanking plate
https://www.google.com/imgres?imgurl...AQMygxegQIARB-
cut the pipe going over the engine and put one of those silicone joiners in with the t piece and put the bov on there and route into the intake somewhere its your choice really
Old Sep 23, 2020 | 07:32 AM
Thanks a lot this really helped
Old Sep 27, 2020 | 09:29 PM
your welcome
jimhockey74
May 22, 2018 06:11 PM
Tommyshelby
Jan 28, 2018 07:50 PM
Constantino Giovanni Borrelli
Aug 27, 2016 06:23 AM
Sverige77
Jul 4, 2011 03:43 PM
tberiau
Aug 10, 2010 03:51 PM
