BOV with a MAF?
Bov
i have a 03 volvo s60 t5 manual, im looking into putting a BOV but i know there are complications because of the Mass Air Flow sensor. i was wondering exactly how bad is it to put a BOV on? or if there are systems that sound like a BOV that reroute air back to the intake.
If you put on an aftermarket bov you WILL loose horsepower. Also My cold air intake sounds bad *** when I shift
Ok. I have a 04 2.5t and I did alot of resaech on the factory turbo. This turbo does have a factory bov built in. That being said you can disconnect that factory bov but you dont want to because it does reroute air back into the system. What I did was buy a cold air intake and then you release the sound of the factory bov.
http://www.eurosporttuning.ca/mm5/me...Code=VL-S60-en
use this as a guide and build you own you need to measure the MAF and buy a cone filter that size then use the stock air box with no top on it. Or you can make a heat shield from a piece of sheet metal I have the EST and its works great but the $199 is a little much for what can be made for $75 or less GL
my850turbo
04-12-2006 11:21 AM
