Is it the brake booster, check valve, or something else?
Old May 30, 2013 | 10:04 AM
dajson's Avatar
Default Is it the brake booster, check valve, or something else?
I noticed most people state hissing occurs when they push on brake but mine happens after I push the peddle down and its rising. Does that still sound like a bad booster or could it be the check valve in the hose instead. Also, the pedal is not difficult to press. Thanks in advance for replies.
Old Jun 7, 2013 | 10:13 PM
Delirious's Avatar
If its soft and hissing then it is the booster, common issue on Volvos 2001+, ATE makes this junk. There is a good write up on how to replace it.
tgaulkin
Nov 27, 2013 03:29 PM
larpio
Aug 1, 2012 06:12 PM
klausrenee
Feb 17, 2011 11:23 PM
Sofar.
Mar 11, 2010 03:45 AM
NYSpeedRacer
Nov 7, 2006 12:01 AM
