Break pad install
RE: Break pad install
It is pretty easy.
You will need a pair of pliers,6mm allen wrench(or 7mm),Big pair of channel locks to push the caliper back.
Remove the 2 black cover on the back of the calipers to get to the 2 screws. Loosen the screws and the Spring on the outside of the caliper.
Then the caliper will slide off. Push the caliper in and install the new pads.Don't forget the silicon Grease or Anti-seize.
tech
06-08-2014 10:25 PM
