Buzzing sound from drivers side engine compartment while driving
Old May 8, 2022 | 05:22 PM
ccahan's Avatar
Default Buzzing sound from drivers side engine compartment while driving
My 2004 S60 2.5 Turbo is making a buzzing sound when running the sound does not change on acceleration it stays the same. It seems to come from the drivers side. Any ideas?
Old May 8, 2022 | 05:48 PM
Could be your Your vacuum pump is running all the time. The plastic switch that controls it is broken. You need to unplug the switch so your pump does not fry. Find and unplug this in the LF corner under the hood. It will be harder to stop the car when first started with no vacuum pump -
Old May 8, 2022 | 06:18 PM
ccahan's Avatar
Default It worked
Thanks Hoonk I’ll be ordering a new vacuum pump
Old May 8, 2022 | 06:42 PM
The vacuum pump runs because the plastic switch breaks. And yes you will be ordering a new vacuum pump once it seizes, but the switch will still be bad and make the new pump run all the time until it fries.
b_eze
Sep 4, 2017 02:24 PM
PetarYanev
Jun 9, 2013 12:02 PM
cameo
Sep 27, 2011 09:49 PM
rslary
Aug 1, 2011 03:27 AM
androide016
Apr 30, 2006 04:07 AM
