Can anyone give me tips on using a cam and a crank locking tool and changing lifters?
Hi I need to change lifters or add shims to the cam lifters [2002 s60 w/2.4 turbo motor]. I think that's what making my motor noisy. It has a loud clicking noise. while it's apart I also want to change the water pump on the chance it could be the water pump making the noise, check the timing hubs and replace the timing belt. I bought a cam and crank locking tool kit on ebay, this one is the same as a volvo dealer would use. I paid extra to get instructions as I never used one before but all it said was that it was the same number tools as volvo uses. Anyone used one of these kits? it comes with a angled L shape plate[ I guess to hold crank? ,two weird Y shaped things about 8"-10" long that can be tightened down, a solid metal thing about 4
" long that has a handle you can turn on the side, the cam locking tool and bolts and what I think are extensions to lengthen it if it needs to be deeper to reach the cams. I could use some advice on using the tools and doing the work. Thanks |
Originally Posted by turbotim23
(Post 523590)
You might want to diagnose your problem before guessing at solutions. Sorry |
