convert a\t gear to Manual Gear
i have problem with my a\t , (s60 t-5 2005)
i want to covert to Manual Gear , It is possible ? Thx :):):) |
possible? sure, anything is possible if you have the $$ for it. a reasonable project? not really.
Originally Posted by Bender
(Post 189532)
You would need: Manual trans Gearshift linkage all the fluid lines pedal assembly reflashed ECU (IPD may be able to do it, around $1500 minimum I would guess) Buy a wrecked S60 and swapping out parts would be the only/best way. You would need ALL the CEM modules from the donor car since they are all married to each other. Just buy a manual S60. |
I have a problem apparently with valve body ( new 1200$ ) , and I hope the gear is ok
i dont know how much it cost |
Far far far less than the swap.
Honestly the swap would probably cost 5k at minimum. |
how much used gear a\t cost ?
