convert a\t gear to Manual Gear
Old Oct 28, 2009 | 12:18 PM
dror_idn's Avatar
Question convert a\t gear to Manual Gear
i have problem with my a\t , (s60 t-5 2005)
i want to covert to Manual Gear ,
It is possible ?
Thx
Old Oct 28, 2009 | 01:13 PM
Bender's Avatar
possible? sure, anything is possible if you have the $$ for it. a reasonable project? not really.
Old Oct 28, 2009 | 03:24 PM
JTapper's Avatar
You would have thousands into it.
You would need:
Manual trans
Gearshift linkage
all the fluid lines
pedal assembly
reflashed ECU (IPD may be able to do it, around $1500 minimum I would guess)
Buy a wrecked S60 and swapping out parts would be the only/best way. You would need ALL the CEM modules from the donor car since they are all married to each other.
Just buy a manual S60.
Old Oct 28, 2009 | 04:31 PM
dror_idn's Avatar
I have a problem apparently with valve body ( new 1200$ ) , and I hope the gear is ok
i dont know how much it cost
Old Oct 28, 2009 | 04:34 PM
Bender's Avatar
Far far far less than the swap.
Honestly the swap would probably cost 5k at minimum.
Old Oct 28, 2009 | 04:39 PM
dror_idn's Avatar
how much used gear a\t cost ?
thomaskr
Apr 2, 2010 08:30 PM
Scott6
May 29, 2009 06:00 AM
joey99
Suspension
Mar 23, 2008 08:59 AM
robber
Feb 10, 2007 11:35 AM
