Coolant leak from firewall - 2001 S60 T5
Old Jan 14, 2011 | 01:19 AM
KeithS60&V70T5's Avatar
Default Coolant leaking from Grommet on firewall - 2001 S60 T5
I have coolant leaking from the lower driver's side firewall. It is coming out of a rubber grommet and leaks about 2 drops a minute. I have attached a picture with the grommet circled and a link to a video to help better identify the location of the grommet.
I would appreciate any help identifying the source of this leak and the best and worst case solution to stop the leak.
Thank you for your time,
Don
Video Link http://dl.dropbox.com/u/14576182/MVI_2525.AVI
Attached Thumbnails Coolant leak from firewall - 2001 S60 T5-firewall-leak.jpg
Last edited by KeithS60&V70T5; Jan 20, 2011 at 01:36 AM. Reason: Reworded to hopefully get some help on this.
Old Jan 20, 2011 | 01:31 AM
Please don't all reply at once people.
Old Jan 20, 2011 | 08:02 PM
dsharp's Avatar
The only coolant in that area is the heater core and the 2 hoses
Old Jan 20, 2011 | 09:37 PM
Thank you for that. I need to find out if that grommet was there for leak drainage or if there was a hose that was once there. So far it does not look good for my heater core. More fun repairs ahead I am sure.
Old Jan 20, 2011 | 10:16 PM
need2fix's Avatar
is your carpet wet inside of car?
Old Jan 20, 2011 | 11:54 PM
No. The carpet is dry.
Old Jan 21, 2011 | 12:18 AM
need2fix's Avatar
does your coolant level drop? im asking cause your a/c drain drips down on that side
Old Jan 21, 2011 | 12:59 AM
Yes. I confirmed that it is indeed coolant. I have been refilling the coolant and have compared the fluid color, smell and texture.
Old Jan 22, 2011 | 12:28 AM
dsharp's Avatar
I have the same model S60 and had the engine out to replace it. The engine compartment is so tight that I had to hook the hoses on the engine before it was all the way in. If it's turbo'd you can get a little more visibility if you remove the air intake.
(Austin)
Jan 10, 2013 11:40 PM
Volvo V70R
Sep 3, 2011 10:58 PM
m3rd
Jan 18, 2010 10:30 PM
Psaboic
Jun 6, 2006 01:34 AM
Red XC
Oct 4, 2005 01:43 AM
