A couple of timing belt questions
Hi everyone,
I plan on changing my timing belt soon and I have a couple of questions:
How big is the center screw on the vibration dampener?
Do the four screws on the dampener really have to be replaced? I am assuming the screws are removed then are used to hold the counter-hold in place, until the belt has been swapped.
Any other advice greatly appreciated!
I wouldn't remove the damper unless you absolutely have to. I recently replace the timing belt on my '02 S60 2.4T and didn't bother removing the damper. I just removed a little plastic shroud on the bottom side of the damper and the belt slides in/out without a problem. There were (2) 10MM bolts holding the shroud on. Saves a ton of time, and no need to have special tools.
I don't have the answers to the actual questions that you asked though.
AnEskimo
09-25-2010 08:32 AM
Steamroll9
08-03-2005 06:04 PM
