Drivers Mirror - memory issue
Old May 25, 2026 | 12:40 PM
mattmc's Avatar
Default Drivers Mirror - memory issue
Does anyone else with a mirror that has a mind of it's own?
I only use one key, and have programmed both memory 1 & 2 to have the mirrors set where I like. But, the driver side mirror is (almost) always misaligned. Sometimes it moves as far left (away from the vehicle) as possible. Other times it's off by only .5 inch or so. Nearly every time I start the car, I have to manually adjust it. Despite programming them, when I hold the 1 or 2 memory button, the mirror just moves left. The other mirror, both seats, and the steering wheel are always perfectly set. Any thoughts?
Old May 26, 2026 | 04:39 AM
Rochgolfer's Avatar
Deselect key memory settings from the vehicle settings menu and the mirror should stay where you set it. Since only using one key this shouldn’t be a problem.
bblooz
Aug 2, 2022 12:41 PM
urdrwho
Oct 7, 2015 06:32 PM
elmo_allen
Oct 11, 2009 05:28 PM
magak2572
Feb 25, 2008 08:09 AM
lotusing
Feb 10, 2007 10:20 AM
