Driverside mirror setup loose?
Old Sep 24, 2008 | 10:40 PM
swedes60's Avatar
Default Driverside mirror setup loose?
Another problem I recently discovered. The driversside mirror "setup" is loose. I tried to find a way to get it off but it was dark, so I couldnt see too much. How do one tighten the mirrorbase? I also found out that there were 2 lights under the mirror which doesnt light up. What kind of bulb fits into those things?
Many thanks
Old Sep 26, 2008 | 01:51 PM
swedes60's Avatar
Default RE: Driverside mirror setup loose?
buump
Old Sep 26, 2008 | 07:55 PM
The entire plastic part moves around? Or just the glass?
Not sure of the bulb size. They should some on when the yellow button on the remote is pushed. I also think they come on when the car is unlocked.
Old Sep 27, 2008 | 03:04 AM
swedes60's Avatar
the entire upper side of the plastic moves + mirror. Yes I thought so too about the lights, but they dont come on at all.
Old Sep 27, 2008 | 07:26 AM
If the entire assembly flops that usually means something inside broke.
The part where it attaches to the door is tight correct?
It is loose at the hinge point correct.
For the light you can usually push the glass in on one side and using a flashlight and skinny long screwdriver see the tab for the light and press it and pop the light out.
Old Sep 27, 2008 | 03:38 PM
swedes60's Avatar
"The part where it attaches to the door is tight correct?
It is loose at the hinge point correct."
Correct. I will go check it out more closely now, but as I remember, the lower part is tight but the big part above it was a little loose.
Old Sep 27, 2008 | 03:40 PM
The something major is usually broke.
Old Feb 22, 2022 | 10:19 AM
Ryan101b's Avatar
Hey Swedes 60. how did you resolve the loose plastic mirror set up. both of mine move with snow removal.
IHdieselfan
1998-2000 model year V70
Sep 2, 2012 09:34 PM
joefloresvolvoforums
Dec 24, 2010 01:21 AM
MikeB28
Aug 19, 2010 05:20 AM
MontyR
Oct 25, 2009 01:33 PM
