Emissions code p2404 evap system
Old Aug 17, 2018 | 02:47 PM
Mountainduc's Avatar
Default Emissions code p2404 evap system
Has anyone had any trouble with this code popping up? I have a 2007 S60 T5 with this code and possible issues are, purge control silonoid, charcoal canister, holes on vacuum lines, faulty pressure or flow sensor. I would prefer not to throw a lot of money at it. I’ve seen it could also be the gas cap, but mine seems fine.
Old Aug 17, 2018 | 04:03 PM
tony1963's Avatar
P2404 Description The Engine Control Module (ECM) checks power consumption on the Leak Detection Pump. The Diagnostic Trouble Code (DTC) can be diagnosed when the leak diagnostic system is run. A diagnostic trouble code is stored if the current consumption of the pump in the Leak Detection Pump unit varies too much during the reference phase.
Read more: https://www.engine-codes.com/p2404.html
Old Aug 18, 2018 | 08:49 AM
Thank you, that helps me narrow it down!
jrmcgove
Jan 3, 2013 04:18 PM
mrford55
Dec 9, 2012 06:47 PM
Volvo4Life97
Apr 21, 2012 11:59 AM
elcs70
Jul 29, 2009 12:48 AM
doublegranch
Dec 15, 2008 01:25 AM
