Engine rattle on acceleration
I have a 2006 S60 that has an engine rattle when accelerating. If moving at an idle it's fine. But as you accelerate it rattles from the engine and then stops after reaching 20 MPH or so. You can sometimes hear it rattle when cruising and accelerating. If I put it in neutral and rev the engine, I can't hear it. So I can't listen for it looking under the car or hood.
Thanks in advance for any advice.
- Jeff
- Jeff
could be related to the gas...sort of a ping noise????? try replacing the gas filter and also upgrading the gas or getting gas from a major gas station and not just your average joe's station...I was watching a new story that was showing some stations gas was not the octane stated at the pumps when they tested it, other were fine...not sure if this is what your trying to explain but it almost sounds like your referring to a ping...if not please repost and I am sure someone on this site can help you
Thanks for the response. I'm not sure about it being a ping or not. Wouldn't it also ping in neutral?
My wife was having a power steering squeal checked and inquired about it to the mechanic. He mentioned that it might be a shield or something near the heating element. We haven't been back to fix the squeal yet, so they didn't get a chance to fully check it out. I hope that it is some sort of rattle that I can fix, but I don't know where to start and thought someone here might have heard of this problem. The power steering is going to be expensive to fix, so I'm hoping this is cheap to fix.
Thanks again.
- Jeff
Thanks again.
- Jeff
Thanks again.
- Jeff
Thanks again.
- Jeff
Engine knocking - Wikipedia, the free encyclopedia sounds like engine knock witch u Will only hear under accel or a lode
volvorecycle
07-22-2015 07:44 PM
