Rattle sound during acceleration
Old Jul 9, 2007 | 06:01 PM
alpine's Avatar
Default Rattle sound during acceleration
I have noticed lately that when I accelerate I hear a rattle sound in the engine compartment. No change in the car performance, just a rattle sound.
any ideas
alpine
1989 240 DL 210,000
Old Jul 10, 2007 | 12:32 PM
billofdurham's Avatar
Default RE: Rattle sound during acceleration
Volvo installed several heat shields in the engine compartment and on the exhaust system. Over the years these tend to work loose or corrode around the mounting bolts allowing them to vibrate.
My 240, 740 and 940 all had this problem. Check as many as you can see.
Old Jul 10, 2007 | 11:06 PM
TedH's Avatar
the engine may also be knocking due to something called detonation, do to timing being to advanced...my 740 does this...it depends if its comming from inside the engine or somthing rateling on the car.
Old Jul 10, 2007 | 11:24 PM
VolvoDriver's Avatar
After a long and frustrating period i had a vibration which i could not find, then i did. that was a good day.
i have a b230, there was a pipe running off the A/C dryer/cannister which runs down the the chassis and goes to the condenser or something, besides the point. where this pipe meets the chassis, the vibration would cause contact, creating the quite annoying and demeaning sound. i added a used brake vacuum hose to the immediate area around the A/C pipe, this completely fixed the issue.
Old Jul 12, 2007 | 12:32 PM
alpine's Avatar
thanks I'll check those areas
crashin
Mar 28, 2022 03:05 PM
ashvolvo
Apr 26, 2011 01:13 PM
fredimac
Nov 21, 2008 09:09 PM
captsupermarket
Jun 20, 2007 03:10 PM
alexr2130
Aug 11, 2006 11:25 PM
