engine vibrations
engine vibrations
Hi. I've got a problem with my volvo s60 (05). The engine vibrations transfer into the cockpit. It hapens and is very noisy especially when i move on and reverse. I have replaced a rear mount already and nothing has changed. Could you please give me any advice? Thank you in advance
volvo s60 vibrations
thank you both for your e-mails;
i was moving house and did not have internet access, i am sorry for late response
in the meantime i went to volvo service; they found out that front bottom engine steady bush was split and i have decided to replace it; it did help but did not reduce 100% vibrations
i was told that next step is to replace dual flywheel with clutch
do you know a very good garage in west midlands? can you recommend any? it is expensive and i do not want to replace these two parts in cr*** garage
thanks in advance for any advice
bcolins
2001-2013 model year V70
10-21-2013 08:32 PM
