Fast Idle Throttle Body Question
I have a 2002 s60 with 118K miles.
Lately it has been idling high (1500 rpm) when started, but drops down to normal when put in drive. This morning when I stared her she idled at 3500 rpm, then when I put her in drive she was rumbling like she was going to stall. I turned her off and restarted and she ran ok. Could this be a bad throttle body? And if so, from some old info on Google is this recall item? Thanks! Mark. |
i would look at the IAC valve (idle air control valve) first
no IAC valve in a '02 S60
Originally Posted by jda2000
(Post 296636)
well in that case there are many other things to look at idle issues always have bugged me =/ is this car new to you? also does this happen every time you start the car or only on cold starts? |
