Front rotors - which size 286mm or 305mm
IPD says this about my 2002 S60. "These models have two brake rotor diameter options: 286mm & 305mm"
Is there a way to know by looking which size is on my car? |
20 mm is a bit less than an inch. (286/305)
Measure with a tape/ruler. in inches from center of hub to edge of disk times 2 Then times 2.54. If you can see across the disk use a flexible tape measure |
I'd call the dealer (Volvo parts) and give him the vin and he'll tell you.
That sounds easier than measuring. :cool:
Originally Posted by pjsmithres
(Post 420536)
Originally Posted by urdrwho
(Post 420540)
