Front rotors - which size 286mm or 305mm
Old Oct 21, 2015 | 12:27 PM
urdrwho's Avatar
Default Front rotors - which size 286mm or 305mm
IPD says this about my 2002 S60. "These models have two brake rotor diameter options: 286mm & 305mm"
Is there a way to know by looking which size is on my car?
Old Oct 21, 2015 | 03:00 PM
pjsmithres's Avatar
20 mm is a bit less than an inch. (286/305)
Measure with a tape/ruler.
in inches from center of hub to edge of disk
times 2
Then times 2.54.
If you can see across the disk use a flexible tape measure
Old Oct 21, 2015 | 03:01 PM
pjsmithres's Avatar
I'd call the dealer (Volvo parts) and give him the vin and he'll tell you.
Old Oct 21, 2015 | 04:35 PM
urdrwho's Avatar
That sounds easier than measuring.
Old Oct 21, 2015 | 04:45 PM
ES6T's Avatar
Some won't tell you if you're not buying from them so you might have to call around.
adamsrotors
39
Jun 25, 2015 01:01 PM
adamsrotors
49
Jun 25, 2015 12:58 PM
Jabber
Oct 31, 2014 11:30 AM
mrvolvos60
Sep 11, 2014 07:39 PM
IS300M
Aug 19, 2010 02:24 PM
