Front Wheel Drive in the Winter
FWD is different than RWD driving. If your nose slides on a FWD vehicle, you point and shoot in the direction you want to go, but turn the wheel no more than 10% off straight.. or you'll quite possibly lose it and do a fantastic 180°+ spin around. If your nose slides on a RWD, you let off and it should straighten out with some clever braking (ABS brakes you hold, non-ABS you stab-brake).
Drove an '87 Cadillac Fleetwood Brougham d'Elegance (fancy name for a rehashed Delta 88 body/suspension) on 1/4" of untreated ice from Wilton, NH to Antrim, NH on Rte 31 when a sudden rainstorm came up at ~32 deg then froze.
All-in-all, FWD is superior to RWD in snow. I'm assuming this is your first FWD vehicle.
We have a FWD V-60 and it did fine last winter with the one exception of a heavy wet snow. I misjudged how deep it was going around a corner and got the car hung up in the snow. AWD might have gotten me out of it but otherwise, I"m perfectly happy with FWD.
The FWD has an electronic locking differential that also helps out when the traction is iffy.
collarandhames
2001-2013 model year XC70
04-13-2012 09:45 PM
