fuel pump replacement s60 2003
I am removing my fuel pump to replace it as it was leaking at the top, I have the lines off and the locking ring off and can slide the pump up and out but can't see what is holding the pickup line in down in the tank. Anyone done this and know what I need to do?
Figured it out, you have to remove the cover into the tank on the left side of the car(fuel pump is in tank on right) overall it was a pretty straight forward job the worst part( besides having to do it since Volvo in South Africa does not have a recall on these faulty pumps) was that the recessed tank access ports for the pump and pick up tube in the other tank were packed with sand and dirt making them hard to unscrew and impossible to remove without getting some sand and grit dropped into the tank even after cleaning it all very well before taking it apart.
1995Volvo850
Sep 28, 2022 12:20 PM
HunnyBunny
Dec 14, 2010 07:18 PM
