Grill removal procedure
Can anyone tell me how to remove the grill from my '02 S60? I assume i need to pull out the four plastic rivet things for the cover around the grill, I tried to pull one and it broke :( . HELP
RE: Grill removal procedure
The grille is attached to the front end via 7 clips. 4 at the top and 3 at the bottom.
You may have to remove the bumper to see behind, to release those clips - remove headlight wipers - detach fog light connection The bumper is held by - 2 screws at the front - bumper bracket at the side (pull the sides outwards to unmount from the bracket) Good luck |
The clips in the top bumper cover (under the hood) you have to push the center in one click then lift the entire clip up to remove.
I have removed the clips and pulled the cover out some and got the grill out before. |
Shweet. THanks tech. I will give it a try.
Thanks tech. I removed the plastic rivets like you said. Then undid the top four clips, located the bottom three and with a thin knife (for lack of a better tool) removed the grill. It took about 10 minutes. Thanks, saved me from removing the entire bumper [:-]
Glad I could help.
