Grill removal procedure
Old Apr 14, 2006 | 02:44 AM
Cornfed's Avatar
Default Grill removal procedure
Can anyone tell me how to remove the grill from my '02 S60? I assume i need to pull out the four plastic rivet things for the cover around the grill, I tried to pull one and it broke . HELP
Old Apr 14, 2006 | 07:12 AM
poopbunny's Avatar
Default RE: Grill removal procedure
The grille is attached to the front end via 7 clips. 4 at the top and 3 at the bottom.
You may have to remove the bumper to see behind, to release those clips
- remove headlight wipers
- detach fog light connection
The bumper is held by
- 2 screws at the front
- bumper bracket at the side (pull the sides outwards to unmount from the bracket)
Good luck
Old Apr 14, 2006 | 09:31 PM
The clips in the top bumper cover (under the hood) you have to push the center in one click then lift the entire clip up to remove.
I have removed the clips and pulled the cover out some and got the grill out before.
Old Apr 15, 2006 | 02:52 AM
Cornfed's Avatar
Shweet. THanks tech. I will give it a try.
Old Apr 15, 2006 | 03:26 AM
Cornfed's Avatar
Thanks tech. I removed the plastic rivets like you said. Then undid the top four clips, located the bottom three and with a thin knife (for lack of a better tool) removed the grill. It took about 10 minutes. Thanks, saved me from removing the entire bumper [:-]
Old Apr 15, 2006 | 09:16 AM
Glad I could help.
icebrick
Oct 22, 2013 08:39 PM
elgallo
May 6, 2011 11:58 AM
wamble
Dec 27, 2008 01:04 PM
garyraygray
Engine & Internal
Oct 28, 2008 03:42 PM
pisque
Aug 3, 2005 03:14 AM
