Heater core leak? 2002 S60 non-Turbo
I found a greenish liquid under my driver side floormat - cannot think of anything other than coolant. No odor detected. Volvo mechanic says he checked the core, hoses and gaskets - found no leak. He replaced the thermostat and I have had no more moisture. My thoughts are as follows:
1. I have not used the heater since the "repair." Should I use the heater and drive for awhile?
2. Could he simply have missed the leak?
3. What would the thermostat have to do with a leak?
4. Totally honest guy - complete trust in his honesty.
Could really use your thoughts guys............
The thermostat would not have much to do with it unless it was broke and building extra pressure.
I would turn the head on and see if you smell coolant.
The o-rings for the pipe might be leaking.
I would have it pressure tested.
ycartf
May 6, 2013 11:19 AM
